NP 205 Figure 8 Clocking Plate
mpascino
Connecticut
Studs/bolts are included. This allows the tcase to be clocked up 18 or 36(flat) degrees and will retain the input bearing as the stock adapter is designed to. All 8 bolt holes remain unlike some other clocking plates out there. An alignment ring is indeed included.
$145 shipped to your door. Custom configurations always welcomed. 3/8" thick to maximize spline engagement. New fine thread studs maintain strength and eliminate the need for a thicker clocking ring.
Regards,
Mike
TTF
Mounted
18 Degrees
36 Degrees
I can't see any reason why it wouldn't. Someone on the board here purchased on a couple months back for the exact purpose, maybe they will chime in.
Thanks,
Mike
