elks
OK so I am just getting ready to replace the rear pinon seal. As I prepped for the job I noticed a little play on the transfer case out put shaft. I am running the factory rear 12 bolt, and the 465 tranny with a 205 xnsfer case.
What should I need to replace to fix the end play issue? It is side to side play not in and out. I am thinking a new seal and the out put bearing.
Is there anything special to consider when doing this? I am trying to keep it in the vehicle and fix it in a day.
Thanks a ton...
Thanks a ton...
