I'm interested in running my NP205 fulltime in 4x4 even on pavement. I know this will cause problems with binding. Any solutions out there to run a NP 205 fulltime 4x4 on pavement?
There's no differential between front and rear like a 203. It will drive wierd. Why not just leave the hubs locked in and shift the tcase in and out on the fly?
Around here there can be ice/snow and bare pavement on the roads. So it does not make sence to unlock the 4x4 on pavement when in a few miles I could be on snow.. a few miles later back on pavement.
I now the NP203 can run fulltime 4x4 on pavement. Interested if it is posible to have the NP 205 run fulltime 4x4 on pavement.
there is now way to make a 205 a "full time" case.
NP203's have a "Dif" in the 4 Hi and and 4 Lo postions and as such it sends power to the wheels with the least amount of traction. If you remove the either drive shaft while the case is Lo or HI the truck will not move.
Now In Hi-Loc or Lo-Loc the center differential is locked together so equal power is sent to both front and rear regardless of traction .
when you convert a NP203 you eliminate that "dif" and it acts just like a conventional "part" time Case
The NP 205 is a part time case meaning your in 2-wheel or your in 4-wheel.
Leave the hubs locked in and shift from 4-hi to 2-hi as needed otherwise drivetrain damage may result.
Could I run in 4-hi for extended periods on pavement with a NP205?
and learn to drive theres no need to run in 4x4 that much it wastes gas and wears out equipment faster
just a thought..
