I recently rebuilt my NP203 as well as the stock shifter. I painted the internal parts of the shifter with several coats of graphite paint. I'm curious if the shifter will function longer without grease to attract grit and grime. Anyway my question is about the rear output seal. The kit came with a seal but it's too small. I tried an NP205 seal which was still too small on the OD. The ID is correct at 2.125" but my OD on the case is around 3.37". It's hard to measure correctly with the shaft in the way. Has anyone had this problem?
