NP203 Removal from 74 Blazer with TH350
Nah man dont overthink it, now you know the torque converter thing is last, that will make a world of difference over before, and you got a lift, with me its 2 of us layin under man handling the SOB, just take your time, relax and all will work out. When you start worrying about stuff it always makes the job feel much more tedious. Just think "im just slappin in a new tranny, no big deal :D"
I may have to find somebody to help me that knows what they are doing...at least they can hand you wrenches...when you are doing it yourself you have to get up from under everytime...I must have crawled out and up a million times...
Yes, fortunately ive always got a helping hand with stuff like this, so i understand how you can feel like its so much more difficult. Can you get somebody to help? even just to work the lift up and down while you direct the tranny??
Flex plates are not that expensive, i would just put a new one on for peice of mind anyway, and unless it was really gettin torqued on (and idk if those shafts are hardened, but i would imagine they are) you shouldnt have messed up the shaft.
I'm not sure that the shaft was even in the torque converter when the backend went down...but I ain't kidding...that big honkin' NP203 is like...well...it's like a lead block on the back end...
Thats what i meant by balancing the weight on the lift because I knew that tcase would be heavier than the tranny.
Even with the hoist, I am still going to have to buy a transmission floor jack...you can't get to the transfer case through the floor tunnel like you need to...you can manage to get a strap around it but when I go to put it back on I want more maneuverability and from the bottom side.
If you can get somebody to work the hoist you could move the tranny around where u need it. If you cant then yes a tranny jack would be better if you must be by urself. I dont do these things without help from a friend, I help them on there stuff, they help me on mine, so Ive always got a hand when i need it, sometimes thats better than having fancy tools and such.
Transmission and transfer case are now at the shop. Said he would have them done by Friday...that's fast.
He is installing the MileMarker part time shaft in the transfer case as well.
pricetag to come later....:doah:
what reman kit for tranny ?
and any shift improver kit ?
i have had great luck over the years with transtar reman kits and noyoyo shift improver kits . these dont snap your neck but firm up shifts and keep from feelin like grandpa's caddy .
oops...I kind of want it feel like grandpa's caddy...whatever it was like out of the factory...that's what I want...
I know it's vanilla, but when you are watching sharks on this island from the shore...you want it smooth like a cloud...no sudden motions...when you are thinkin' about sharks, sudden jerks scare you...:eek1:
Since he is going to be done so soon...I won't be ready for it if I have my engine out...does a tranny store ok sitting on a garage floor for a couple weeks?
Take this all with a grain of salt........
FWIW...
over the many years of working on K5's,,I have found that the best way to remove and install transmissions and transfer cases are to pull them both as a unit unless there just a need to pull the transfer case by itself.
Remove the unit with a transmission jack.
Ratchet strap or chain the unit to the jack base plate tight.....let me say that again. TIGHT.
Let the jack do the work as it was designed to do...500 lbs sliding around loose above my head is not my idea of a good time...
most good transmission jacks have tie down points and adjustment points to tilt the transmission forward or backward or side to side....
I have pulled and stabbed countless transmissions and learned the hard way....balancing transmissions on floor jacks and blocks of wood etc,, prior to owning my own transmission jack....If your not into buying one....rent one.
After the trans is secured to the jack,,,lift the trans unit just enough to take the weight off the cross member....remove all the stuff attached to the transmission and transfer case....
Pull the inspection cover and remove the starter.
Pull the T/C bolts from the flywheel and push the converter into the front of the transmission.
Take a ratchet strap and sling the sump of the oil pan on the engine from frame rail to frame rail...pull it up tight,,,this will support the engine as you remove the transmission...you can also take a few small pieces of 2x4 and wedge them between the block and the firewall....this also works good.
Remove the crossmember and then slightly drop the transmission down a few inches....working from the bottom, pull the bellhousing bolts...
The top two bolts are the hardest to get to,,,dropping the trans down a little gives you better access to them...
an 18" - 24" extension with a swivel socket makes it easy to get to the top two bolts...
once the bolts are all out, slowly drop the weight of the transmission until the engine is supported by the strap or the wood blocks...
At this point you should be able to rock the trans back and forth and it should separate from the engine block....from here,,, it's just a matter of slowly dropping the unit and rocking it and pulling it back an inch or two as you let it down.
If the trans is too high (once the jack is all the way down) to pull it out from under the truck...use a floor jack and wood blocks to lift one side of your rig and roll it out on the jack....
maybe its just me.....but making my tools work for me is a lot easier than fighting, straining and battling when removing and installing a transmission and possibly hurting myself or damaging something....:dunno:
Chief.....If I were you, I would tell the trans shop how hard the trans came out....they may find the input shaft/ front pump/input bearing was bent or damaged upon removal... it also looks like a bunch of scrape marks on the converter and the hub looks dinged up on the end....not good signs...
I'm getting it rebuilt instead of just a reseal kit...so hopefully everything will get replaced if I damaged anything....getting a new converter with it also.
I'm getting it back in two pieces so I can install transmission first. I probably will pull the engine and install them as one unit though.
What's the hub that is dinged?
attachment.php
It may just be the picture..but if you look at the hub sticking out of the back of the converter,,,,it looks chewed up or dinged across the top...
should be perfectly smooth...the tangs engage into the front pump of the transmission...the input shaft also passes thru here also.....
You got me curious so I went out and took some closeups...it does look funky...however, I am getting a new converter so that will have a new hub won't it?
yep. but let the tranny shop guy see this so he can make sure the pump in the tranny is not all mared up.
and he will prob need this for a core to swap withthe new or reman you get.
the question is is did I do this or is this the reason it was leaking like crazy?
some you prob from dragging tranny off. but the end looks chewed up a bit all the way around .
can you wipe the sleave off dry with a rag and get better pic with no oil to have reflecting ?
Kinda looks like old damage to me, although you may have added a scratch or two. :dunno:
Thanks so much to everyone that contributed to this thread...I have a 75 Jimmy I am about to yank the tranny and transfer case out of for reconditioning (Motor is already out as of last week)......This has been invaluable info as my Haynes Manual was less than helpful for this job.....
