Np205 flanges
ford 205's run 32spline front outputs, so a stock front flange from one of those will work on your 32spline output. i've got one for my front output, but im using a HAD flange in the rear (to match the driveshaft). the HAD flanges are second to none in quality, but if you can get away with using the ford flanges front and rear, it would save you some money
the ford ones are also nice, because they have the same bolt pattern as the stock chevy shafts, so you dont need a new shaft (or modify old one) to run them
an np208 front flange is 32 spline, ill be using it on the rear of my K5. i had the face turned down to accept my driveshaft though.
I like my flanges from HAD, not the cheapest way to go but good quality.
Have you called over to Front Range Driveline? Talk to Bill see if he can help you out ;)
