Np205 front output seal
Recon 78
Installing seals from my ord rebuild kit
Going from 10 spl front output to 30 spl with flange
Can't figure out which way the seal goes, springs on both sides
Comparing to other seals looks like rubber side goes towards flange
Any help? Thanks
I put the steel side out. I haven't done a 10 or 30 spline front shaft in a while but isn't the rubber side soft and flexible? So if you were to use a seal puller and the rubber side was out, it would just tear the rubber. Steel side out, it will grab and come out.
I used ord’s kit also and I think I used a different seal from the kit. Do you have one like this?
Had a spare from a 203 seal kit so i cut the rubber side
Think you're right obi, the rubber fills in the hollow side of the metal ring
Not the spud seal, but it sure does look similar
