np205 front output... special socket? wtf?!
jekbrown
I am CK5
Author
TEXAS
go to take apart a furd np205 and even my biggest socket (1-1/4") won't fit over the nut. np... I go to sears, buy a 1-5/16" socket. Which.... of COURSE fits the nut fine, nut won't fit inside the u-joint yoke. Sigh. Is there a special j-tool or is it just a special thin-walled 1-5/16" (as if 1-5/16" wasn't a screwed up size anyway?!?!) or some crap? How annoying. Someone school me up, whats the answer.
j
Same problem - different town.
I bought the Craftsman 1 5/16" socket and took it to the grinder- just tapering the front section enough to slip in and seat completely around the nut.
Have fun!
-I'd like to know myself of a thinner wall 1 5/16" socket.
guess thats what I'll have to do... maybe its time to swing by harbor frieght and pick up a big old set of giant sockets over there for $19.99....
j
goldwing2000 said:
Same size as the D44/10B upper ball joint nut. :D
like I said, screwed up size. :grin: no one should have 1/2 ton axles OR balljoints. :thumb: :grin:
j
Sounds like the same prob. i had with my dana 60, Its a 1-5/16 thinwall socket. I just grinded the socket to fit and it now works for pinions, ball joints, yoke's etc. Did not take longer then 5 mins of grinding
I just went to NAPA and bought a cheap 1 5/16 socket and worked the end of it over with the bench grinder. Viola! Worked like a champ!
Mike
hmmm... if its that little grinding I guess I'll give it a shot.
j
Don't grind on the Sears socket, go find an import 1 5/16" socket, grind on the cheapie. I had the same problem, I used an import socket and still had to turn the end down about 1/16" on the radius.
too late... its all good though. ;)
j
