NP205 part
GreenieK30
Washington
Hi, I am looking for a cast iron NP205 front output bearing retainer plate. Please let me know if you have one for sale. Thanks!
I think he may be referring to the wording being off... Front output, rear bearing retainer? If your front output bearing housing looked like that I would think you were building a "SHOW TRUCK" with no front driveshaft.
Index Number Part Description
1 Yoke Nut
2 Steel Washer
3 Rubber Washer
4 Rear Output Shaft Yoke
5 Output Shaft Oil Seal
6 Rear Oil Seal Retainer
7 Rear Retainer Gasket
8 Rear Bearing Snap Ring
9 Rear Output Shaft Bearing
10 Speedo Gear
11 Rear Bearing Retainer
12 Rear Retainer Gasket
13 Rear Output Shaft Bearing
14 Low Gear Retaining Ring
15 Thrust Washer
16 Thrust Washer
17 Low Gear Roller
18 Roller Spacer
20 Low Gear
21 Low Gear Thrust Washer
22 Low Gear Pin
23 Rear Output Shaft
24 Sliding Clutch
25 Output Shaft Roller
26 Thrust Pilot Washer
27 Pilot Roller Lock Ring
28 Input Shaft With Gear
29 Shift Rail Poppet Screw
30 Ball Poppet Spring
31 Spring Poppet Ball
32 4WD Indicator Switch
33 Poppet Screw Gasket
34 Front Input Shaft Bearing
35 Input Shaft Bearing Snap Ring
36 Input Shaft Snap Ring
37 Oil Seal Adapter
39 Transfer Case Adapter Gasket
40 Transfer Case Adapter
41 Transfer Case Adapter Sleeve
42 Sleeve Retaining Ring
43 Adapter to Transfer Case Gasket
44 Trans To Transfer Case Adapter
45 Idle Gear Shaft Washer
46 Idler Shaft Lock Nut
47 PTO Cover
48 PTO Cover Gasket
49 Clip
50 Magnet
51 Partial Case
52 Idler Shaft End Cover
53 Idler Shaft Cover Gasket
54 Idler Gear Shaft
55 Rear Wheel Shift Fork
56 Shift Rail Interlock Pin
57 Front Wheel Shift Fork
58 Fork To Rail Pin
59 Front Shift Rail
60 Rear Wheel Shift Rail
61 Shift Rail Oil Seal
62 Shift Rail Link
63 Idler Gear Bearing Cone
64 Idler Gear Bearing Cup
65 Idler Gear Bearing Spacer
68 Idler Gear
69 Idler Gear Spacer Shim
70 Front Output Shaft
71 Front Output Sliding Clutch
72 Front Wheel High Gear
73 Front Output Thrust Washer
74 Front Output Shaft Bearing
75 Front Output Bearing Snap Ring
76 Rear Bearing Front Output Shaft
77 Front Output Shaft Bearing Retainer
78 Rear Bearing Retainer, Front Output Gasket
79 Low Gear, Front Output Retainer Ring
80 Front Output Thrust Washer
81 Low Front Output Gear
82 Low Gear Roller
83 Front Output Roller Spacer
85 Front Retainer Gasket
86 Front Bearing Retainer
87 Front Retainer Seal
88 Yoke Flange
89 Rubber Washer
90 Yoke Nut
I'm sorry but...
[hijack]
Year of the case (might help find cover)? 3spd version adapter? Never seen the iron cover on a 205 before, very neat.
[/hijack]
Was that mated to a 3 speed tranny? Adaptor looks like 2 of them I once had.
I believe Chevy offered two different 3 speed manual trans in front of the NP205, a Saginaw and a Tremec. They are not many of them around or info about them either.
This adapter is made by Rockwell.
That adaptor looks different from the two 3 speed adaptors I had.
Which one is yours and what did I have?
Then the GM employee who came up with the wording didn't do a good job in matching the naming to the bearing it represented... Line 76 is "rear bearing front output shaft".
Either way, I think everyone should know what your talking about.
