k20
3/4 ton status
Working on my NP205, when I bought it the Rear Bearing Retainer (http://www.offroaders.com/tech/Diagrams/np205.htm number 11) was loose, the bolts had been removed because it had a PTO on it that had been removed. Anyway, when I found some bolts I tightened it down and the shaft locked down, if I kick it into 2wd, the front yoke spins fine, but the input/rear output is locked down solid.
I backed all the bolts off a few turns and it was still tight, so I popped the bearing retainer back up and it spun fine until I ran the circle of bolts again, and then once I did that it was locked down. I popped the cover back up again and just barely tightened the bolts and it still spun but once I tightened them up, again it was locked down...........wtf.......
