BrianDamage
in the process of rebuilding my NP205. I'm robbing the rear output of an older model in order to eliminate the slip-yoke on mine. Anyway,the newer case has the red plastic speedo gear. The older one is metal. Same in every way, but metal...us this "more desirable" to keep? Only reason I can think is it might be less likely to break for some unknown reason...didn't know if there are any problems associated wit the the metal ones.
