OK, here's the backstory, This is a Dodge Divorced tcase.
Ground the rails for independent front and rear control. Seems to shift into and out of each position properly. As in the detents engage.
Swapped out all the yokes for the appropriately sized yokes.
Here's the situation,
Accelerate and abruptly get off the throttle and there is a significant growl or gear noise coming from the tcase.
Do the yokes set end play in the 205? I didn't think they did but now I'm doubting.
Any other suggestions? I've ground rails for 4 different 205's now. I've missed the mark one time and you could easily tell it wasn't working properly before the reassembly. Not entirely sure what happens if ground too far though....
Lube is beyond full so nothings running dry.
