WJACKSON11X
Last time out I broke my front output CV on my square driveshaft (front). I had a 1410 driveshaft laying around from a F-250 with a flange on one end and a yoke on the other. My idea is to run all 1410 front shaft. I bought a D60-1410 yoke and hoped to use the flange from the Ferd, but the pilot hole is different size. The holes line up, but not the pilot hole. Do they make a 1410 flange that will go on the front of the 208? I'm not wanting to run a CV shaft, is this possible? I think I saw someone on here running one. Will I run into crossmember clearance issues? I've already welded the 1410 yoke on 2.5" 1/4 wall square tube. Left is the Ferd flange, right is stock 1310 cv
