DPI
Well, here's the finished interior shot. I installed new carpet that I purchased from Home Depot. I cut and sewn it to custom fit. I think it looks OK.
ttt, do u think you could post pics of the 241 shifter mechanism?
So how do you like it so far Daniel?
are your brakes able to stop it in 11.7:1 or do you have to put it into neutral?
hey daniel, if you have the time do you think you could get a measurement from the mounting surface of the 241 to the rear yoke centerline of your atlas please? Also how long is your rear driveshaft, and what angle is it running at? Thanks.
Here's some measurements for you.hey daniel, if you have the time do you think you could get a measurement from the mounting surface of the 241 to the rear yoke centerline of your atlas please? Also how long is your rear driveshaft, and what angle is it running at? Thanks.
I used the 241 passenger drop 241 adapter. The TH350 output shaft is 1" shorter than the 700R4. An example is the Atlas adapter. The main mount / adapter is the same for the TH350 and 700R4, but the 700R4 has an additional 1" round spacer that takes up the extra 1" of the 700R4 output shaft. Make sense?
