np241 fye
hd-10
lemoore, ca
np241 sye
has anyone put there sye kit in the 241? if so i need measurement for my driveline, have a 4 inch lift with 1"zero rates. would like to get the measurment before i start so i can get my driveline now thanks for any help
you gonna get the extreme short kit for the electronic vss?? i'm hopefully getting that soon.
i know it's not hard to do just wanted to get my driveline before i started so my truck would still be up and going.
You need to give more info if anyone is going to help you. Like someone said above, are you going to use the standard SYE or are you going to use the short version? Next are you going to run the Yoke or a Flange, which will give us the info to figure out what kind of driveline you're going to run (standard driveline or a CV driveline). This will all need to be known before anyone can help you. If you go with a CV driveline you need the pinion on the rear diff to point directly inline with the driveline, (actually about 2* downward so when under normal driving conditions it will point at the driveline as the axle will wrap some to make it be inline).
