Found Nv 4500 clutch master reservoir
I have the Nv4500 from a 1992 with the front mount passenger slave and the pedal assembly from a 1985 and the master, I’ve adapted them together and need the reservoir for the 80s hydraulic clutch that was for the late model sm465’s
I called Gm they couldn’t find the part number, anyone happen to have the right one?
Visually different than oem but can probably be made to work ok.
The reservoir from my southbend clutch for my dodge appears universal as hell. Probably very easy to make work if you can’t find the stock assembly.
