NV4500 Diesel Vs. Gasser?
botboy
Delano, MN, USA
Ok, so I'm debating whether I put a 465/205 behind my 6.5 in my crewcab, or spend the big bucks and put an NV4500 behind it.
Doing a car-part search, looks like the NV4500 came behind a gasser and a diesel - what's the difference? Just a lower OD ratio, or what?
Truck is an '80 C30 CCSB, originally a 350/TH400/2WD truck, when i'm done plan to have a 6.5 (Mech. PMD from '93 Cube van), banks kit, manual, 4x4 with a D60 up front....I got a lotta work ahead of me :D
No difference. Only difference was that 93-94 models, all of them, had a lower ratio. The only gearing differences in diesel vs gas is in the rear end.
The diesel version has a harmonic damper inside. My NV4500 is a '95 diesel version.
The big round thing on the back is the damper.
Rene
that must be a GM thing because my '98 Dodge nv4500 definately doesn't have anything like that.
It is a GM thing...and goes a long way to keeping 5th gear from coming loose.
Rene
Maybe, I do know the cause is 5th gear rocking against the nut. Heavy load and the transition between throttle and no throttle puts a ton of rotational stress on the gear...and being that it's not full spline it eventually can develop a bit of a play. That rocking motion against the nut loosens it off eventually.
The damper on the GM version sits between the nut and the gear.
I did carefully check the mainshaft on mine for any signs of fretting and saw none...so I put it together using a stock replacement nut.
Rene
I stuck the updated pinch nut on mine, and welded it to the shaft. we'll see how long mine holds :doah:I've got fuel and air components coming to go over 600horse.
Cool (on the 600 hp part)
My 6.2 will never be able to hurt the NV4500...;)
Rene
Rene
I believe the damper was a GM-only thing not specific to diesel. I have two NV4500's, one gas 6.34 and a diesel 5.61 and both have the damper.
