I bagged an internal slave nv4500 from a buddy and have a couple questions to help make this a seamless install. Most of this I gathered searching ck5 so its probably pretty good. Thanks you guys for all the previous postings about it!
97 trans into a 90 Burb tbi350
First is this 36" hose too long? Seems like its on the long side of good. Did I get these an fittings right?
Most important question is how do I know which flywheel and pilot bearing to get? The 350 doesn't appear to be original but probably just a stock replacement.
There's a ton of options when I pull up the catalogs. If I was a betting man, a 97 would be different and I'd install it and ruin something.
This is the the OEM fitment 1990 flywheel. pilot bearing shows different dimensions
Flywheel, 168-tooth, Steel, Chevy, 4.3L, 5.0L, 5.7L
pilot bearing
luk master and slave: 11/16 in. Bore master
GM version is 75 dollars more but by some pictures out there, the have the same numbers on them.
luk clutch kit: Stock Replacement, 1.125 in.- 10-spline, 11.875 in. Diameter Organic Disc, Pressure Plate
Braided hose: Straight, 36 in., -4 AN Female, -4 AN Female
hose adapters: Male -4 AN Male to 12mm x 1.0 Male UniFlare Adapter. Quick Disconnect, Male -4 AN, Straight
pilot bearing
Pardon Our Interruption
www.summitracing.com
