Mikey von
My Th400 is toast.
After speaking with the boss, she said that she will put up with me spending the money and time needed to swap in the 5 speed I want.
Just doing a quick search on craigslist, I found a Nv4500 with clutch, bellhousing, transfer case, clutch pedal, hydraulics, drive lines from 93 chevy 2500 truck asking $1600.
If I get a 6.2L flywheel and anything else needed?
Will the pedals (or just clutch pedal) from a 93 fit my 1989 suburban?
As long as I get the bell housing with the transmission, I should be fine there correct? My NP241 TC will bolt right up correct?
Finding hydraulic pedals can be a problem though.
