84CUCV
3/4 ton status
asking for a friend. found a totaled 02 dodge 1 ton 4x4. his truck has a 6.5 and round pattern 205.
thanks
thanks
thanks
Hmmm shouldnt they be the same bell as a 4500? I always thought it was the same trans with another gear really.
http://www.4wheeloffroad.com/techarticles/131_0205_nv5600_transmission_custom_swap_kit/index.html
A 2002 Dodge with a np 205? Never heard of that.
Its doable but expensive and not much of a gain really save the 5600 for the cummins guys
the 205 is in his k30
I'm gonna go out on a limb and guess this K30 is still square body and the T-case is a stock round pattern 205...but the original 6.2 was replaced with a 6.5.
As for the rest, i can't say much about the NV5600 other than it was never ofered in a GM and is quite a bit larger and heavier than a NV4500. The GM 6 speed was the ZF S6-650. All aluminum, integral bell, and pretty beefy. Again it's physically larger than the NV4500, but at least should play nice with other GM engines. Not the most common tranny, in fact I think GM only used it for 4 or 5 years before dropping the manual tranny altogether.
Rene
. I have two ZF's and had 3 2cyl deeres. They just start slipping or giving you hard peddle
. I run South Bend units in both mine.the stock dual mass flywheels were junk and they sounded like a 2 cylinder john deere tractor when they went bad, heck alot of them "knocked" from the factory.....
They don't knock or sound like a 2cyl deere's,not sure where ya got that. I have two ZF's and had 3 2cyl deeres. They just start slipping or giving you hard peddle
That 5600 is worth a fair bit to the right person. Plenty of guys willing to buy them to replace pos auto's with.
friends of mine (3 brothers and the father) have owned no less than 8 duramax's since 01......all 3 (brand new) of the 6 speeds had the spring go bad in the dual mass fly wheel, two of them were making light noise off the lot brand new and just got progressively worse til they would go POP, POP, POP, POP like an old 2 cylinder deere when they were running....dodges had the same problem with their dual mass flywheels but they just didnt have as many go bad as the chevys......
