We have an '02 Durango, which has had a check engine light on for ~2 years now...
No drivability issues, just an annoying light. It needs it's first emissions test this month so I broke down and picked up an Innova scanner to see what code was set. P0440 set, evap system. Most common issue I know of for that code is gas cap related, so I pick up a new gas cap, clear the codes and re-scan. shows no codes, but I have an amber light on my scan tool. This tells me the computer has not run a diagnostic on one system (evap...duh)
I break out my google fu and dredge up the parameters the PCM looks for before running the diagnostic. It's a two part deal, the first part runs after the truck has been idling for 5 minutes, then driven at 35-45 mph for 2 minutes. The fuel tank must be between 50% and 85% full. The second part occurs after the trcuk has sat for at least 8 hours without being driven (cold soak). Start from cold, idle for 4 minutes, then stop and go traffic for at least 5 minutes (smooth accel and decel) then let it idle for another 4 minutes...
What kind of idiot comes up with this? I make a repair, and basically have to make this my daily commuter for the next week and hope against odds that the computer will finally see the stars align and do the self diagnostic...all so I can confirm we had a bad gas cap. Until it does this self diagnostic I can't take it in as their scan tool will show the evap system diagnostic is in a "has not run" condition.
Happy with my scan tool though...it does all the generic OBD2 codes, as well as the manufacturer specific codes (broken down by engine, tranny, etc), also does live data, and of course tells me which systems have or have not run self diagnostics.
Still...this is way too much tech for a bad gas cap.
