George_Pimpdaddy
Just a quick question that came up about gas milage is it safe to dd my 350/700r4 combo in od or should i be in d all the time till about 80km/h ish? thanks for any input im just trying to cut the beast back a bit
BrianDamage said:OD all the time unless you are towing, or just want a harder shift (when you want to "get on it")
I don't know why but it certainly does! Not neck snapping shift kit style shifts but thet're definately firmer in D.PsychoticDeadGuy said:so you get harder shifts when not in OD? i dont understand how that would matter. could someone explain?
stockk5 said:when i am in OD.. and my truck is on a slight uphill its like it has NOOO power, so i have to drive in D,, unless im on the highway i wont use OD.. this is w/ a k5 w/ a 305, and 342 gears and 33" tires
