My 1988 V10 Suburban has a Dana 44 from a 1975 K20 under the front of it. It needs ball joints, not badly, but they are due to be replaced. I use to have 35x12.50x16.5" BFG Mud Terrains on it. I blew one out, so I swapped to a set of 37x12.50x16.5 Goodyear Hummer take offs. I never had any death wobble issues before the tire swap. After the tire swap it was almost undriveable.
That being said, I had slammed into something and bent the tie rod pretty bad, and destroyed the steering stabilizer. The tie rod ends were COMPLETELY shot anyway, so I swapped on a different tie rod with good ends that I had sitting around. The only problem is that it is for the wrong year, so I can't use the steering stabilizer with it. I already ordered an aftermarket clamp on steering stabilizer mount for the tie rod, so that should take car of that.
When I swapped on the new tire rod, it took care of MOST of the death wobble. I am guessing new ball joints would take care of the rest of it. The odd issue is that it only death wobbles between 35-45mph, and only on pavement (it is also intermittent, it doesn't always death wobble). It will not death wobble on gravel. I found that quite odd, and was wondering if anyone else had experienced that before. Even stranger yet is that it has snowed here, so driving on snow pack doesn't change anything. Snow pack on gravel, no death wobble. Snow pack on pavement, intermittent death wobble. How does the road surface have any bearing on it, if it is covered in snow pack???
Martin
Martin
In my situation, tires and alignment made the difference between no wobble and bad wobble.
