Odd question
Big Ray
The Older I Get, The Grumpier I Become!
Eastern NC
How much height is gained switching from a 10 bolt to a 14 bff?
I figure an inch minimum
How much height is gained switching from a 10 bolt to a 15 bff?
Never heard of a 15 bff. :doah:
It should just be the difference from the axle centerline to the top of the spring perch. So the radius of the axle tube plus spring perch height.
I doubt it would make much difference but something to consider would be the cast perches found on most C/K 20’s v/s the stamped steel perches found on most SRW C/K 30’s - also square 14B FF’s came in 3-3/8” & 3.5” axle tube diameter's.
