Off Road Parts, Dana 44, 2WD Steering box, high steer Knuckle and arms More!
eagle mark
- In Memoriam -
North Idaho!
DANA 44 FULL SIZE Chevy with new 5:13 gears, bearings and set up, no outers, $200.
Two Dana 44 carriers for 3:92 and up gears, $50.
Dana 44 right side high steer knuckle, milled and drilled, $60. SOLD!
Chevy 2WD steering box needed for high steer on 4x4, $75. SOLD!
Two high steer arms, drilled and tapered for knuckle, NOT drilled for TRE Or Heim Joint $75. SOLD!
Dana 44 front axle shafts, R/L inner and outer, $40.
Complete HydroBoost brake system, $100.
Big block Chevy TBI unit, no injectors, $100.
4.0L HO head for 258 Jeep engine, performance mod with 2004, tuned port, MPFI intake and DIS distributor, $200.
New 10mm spark plug wires, $40.
RobinAir R12 and R134a recovery and recycling machine with one R12 tank, work excellent, $200.
Hot Road and off road GM ECM chip tuning, LT1 reflash, EFI conversion engine transplant wiring and diagnostics, $50 up local.
Mark
What condition is this in? Thanks!
How much for the d44 knuckle shipped to 80807?
Price of the knuckle and whatever shipping costs, I don't know? Think it'll fit in a priority mail so pretty cheap.
Fine, I was driving the truck it came out of. Little dirty, no leaks, been inside on a shelf 2 years. Probaly $40 plus to ship depending on your location...
the knuckle will fit the ~$15 usps flat rate box, even better if the studs or B-joints are missing
and the steering box cost me an arm and leg to ship, IIRC $26 Fedex, sucker is heavy
I'll definitely take the Dana 44 right side high steer knuckle, milled and drilled, and the two high steer arms.
Let me know how much shipped to zip 97801.
Thanks.
I'll take the High Steer knuckle, the 2wd steering box, and the high steer arm. shipped to 92584, Paypal ready
I should disclose that you need 2 high steer arms, I have 2. Both are drilled and tapered for the bolts on knuckles but neither is drilled for Tie Rod Ends or the other joint that uses a bolt. Both are long enough to use a tie rod and drag link! I didn't know what I was going to use at the time and the machine shop here charges $10. for tapered tie rod/drag link holes so that's the way I ordered them.
You can ship a steering box in a large flat rate USPS box for $15.00, i've done it before.
I'll definitely take the Dana 44 right side high steer knuckle, and the 2wd steering box then.
Thanks.
