Official: Post your truck goals here
Well my 500cid/TH400/NP205 is going in now, I have the NP203 to go between the 205 and TH400, I just need to fab up the adaptor.
I wouldn't mind getting a M15000 for the front and throwing the M12000 out back.
Groove my new 42" TSL's.
New Stereo.
Soft Top.
Locker For the D60.
Have a good freakin Time!
Think smaller.. not the end result..mini goals every 6 mths.
If you finish one early start on the next one, but do not start a new mini goal, until you have finished one...
My mini goal right now is a cage..10pt or better...Next mini
goal is 37 goodyear mtr...If i think of everything i want to do it hurts right between my eyes..Is this normal?
ALL HAIL THE ALMIGHTY SAWZALL
74 JIMMY 35MT 4" D44/12B TRIMMED FENDERS
good advice for some, bad for others. i like big goals so if i'm not gettnig much done i don't be myself up and i have time left.
However i need to break down what i need right now to get it wheelable.
241 SYE/1350 CV chaft from HAD- $500
4.88 14FF gears- $189
Install (if i don't do it myself) - $200
Front driveshaft- $160
Cut springs perches, re-weld for good pinion angle- $100 but only because no welder.
So $1149 give or take. To be daily driveable i need just the SYE/Driveshaft.
Hmm- hopefully 2-3 weeks on the SYE!
oh, can i install the SYE without taking the case off the truck?
by mid december
-half cab install
-diamond plate bed floor
-diamond plate floorboards
-HAD rear shaft
-shackle flipped rear
-long travel bilsteins all around
-14 bolt rear
-d44 front
-rear bumper
-front bumper(done)
-stainless braded brake lines
-4" bds front springs(done)
-Edelbrock Thunder AVS off road carb(done)
-hand throttle
hmm I need to get working.
then by next winter /forums/images/graemlins/smile.gif
-1 tons
-5.13 gears
-lockers
-front HAD shaft
-rear coil setup
-42 TSLs
-narrowed front end, bobbed rear.
Some day before I die.
Custom D80's with portals
Intercooled Supercharged 502
Allison Automatic from Chevy HD
ORD Doubler
1410 Driveshafts
445/65R22.5 Goodyears (same as my cement mixer)
22.5 Alcoas
Since I'll probably never see anything but the doubler, I'll settle for just getting the tranny back in right now and maybe 36's by next summer.
Have fun building my suburban and actually have it ready to wheel before the end of the year. Blazer Bash 2004 is the ultimate goal right now.
Oh ya, did I mention running Upper Helldarodo in the suburban. /forums/images/graemlins/eek.gif
Buy next summer I want to buy this engine or a 383 similiar builtforspeed
and then I need
engine stand
edelbrock truck carb
dist, ignition, wires, plugs
gauges
flywheel
torque converter
march pulley system /forums/images/graemlins/cool.gif $$$$
maybe new radiator
and all the other goodies I will need for my engine transplant. /forums/images/graemlins/grin.gif
