For those of you who run zero-rates, 52's or 56's with your axles moved forward and having problems of the draglink and tie rod hitting or rubbing, check out these TRE's below:
Left hand offset:
http://www.teraflex.biz/products/heavy-duty-tie-rod-end-lh-offset-with-stock-taper.html
Right hand offset:
http://www.teraflex.biz/products/heavy-duty-tie-rod-end-rh-offset-with-stock-taper.html
Left hand offset:
Right hand offset:
