So just picked me up a 89 Diesel Jimmy from Mr. Blazer himself (kgblazerfive).
Well the trans is going out it will barely move in reverse (yes the fluid is full). Anyone ever have a transmission cause vibrations? Well vibration is such a mild term, it shakes. But only under load, shaking becomes a vibration under heavy load. It does not do much of anything except glide right along when coasting or under light throttle conditions.
Well sometimes under coasting nothing, maybe just a little driveline vibration, but you go 3/4 throttle in this thing and it feels like clutch chatter except a little slower in pace than a clutch chatter.
I drove it home (about 200 miles) and ending up finding a happy spot in 3rd (its a 700) at about 55. It did well there until I got to a small hill then had to give it throttle to get up the hill, unless I gave it full throttle than the shake became a vibration.
3rd was the happiest gear, overdrive did the shaking thing alot more than 3rd did on the highway and since you are mostly accelerating in 1st and 2nd they seemed to do it all the time.
We checked it over for loose bolts bad u joints bad tranny mounts etc.
I do have a new trans to put in it (thanks Keith) just hoping it will cure my shakes
and I actually had to put in in 4 low to back up a slight incline.
