str8axle55
I have a pressure tester you can borrow if you`d like.
Instead of paying $67+shipping, why don't I just put an air fitting and gauge in place of the drain cock on the radiator, then crank the air regulator on my compressor down to 15psi?
How do i do that?
If you have coolant in cylinder I can't see any other recourse but to pull the head.
Never had a cracked head, so no idea if a very small crack could leak coolant but still provide good compression numbers, but it would be something I'd look for anyway.
I'd bet if you pressurized the cooling system, you'd fill that cylinder up.
Ok so I cycled the engine a few more times to blow all the coolant out of the #7 and redid the compression test. I got 185psi. So now, what does that mean?
How can it leak coolant into a cylinder at the intake gasket?
Never having lost a head gasket, I don't know if you can tell where one has been leaking once you pull the head off or not.
