My timing couldn't be worse trying to call machine shops on saturday of labor day weekend
I won't be able to talk to anyone until tuesday!
Looks to me the inner coils stacked solid and deformed and bent....that probably took out the valve stem seals....
Did you check the valve springs for solid stack when you changed the cam?
Are you running high ratio rockers?
Along with a higher lift cam,the springs maybe stacking solid at full lift....
Would my new roller cam have anything to do with this? I noticed the max lift says .575" hydraulic flat tappet, not hydro roller. My cam has a lift of .515/.530.
However, I don't know if the valves started doing this before or after the cam swap![]()
From what I've been told the extra weight of the roller lifters will cause loss of valve control at lower than normal RPM. I would look at the cam card and see what the recommended spring specs are.I thought roller cams required more spring pressure. From what I've been told the extra weight of the roller lifters will cause loss of valve control at lower than normal RPM. I would look at the cam card and see what the recommended spring specs are.
The head gasket Top (head side):
A close up of the #7 cylinder:
What's with the pitting on the exhaust valve?
What shop did you take it to? Recent events may have us looking for a new engine shop when we need Volvo heads redone.
Is it on Rt.79 in Berkley MA..??..I think that place was or might still be a motorcylce shop ,if its the same place I'm thinking of..I have a friend that lives a few houses away from there...I'll check their web page out!..
.....................................................................................................more than once we got caught parking with our girfriends on the many dirt roads in Berkley,with beers or hard stuff,and were just told to "get the heck outta here,whatcha trying to do,make me WORK?"...we had more drag races and bonfires in Berkley than any other place around...........................I did have a few friends from Bridgewater too.................................................................................................................You could get away with a lot back in those days...but you didn't mess around in Fall River!..the cops there didn't fool around,if you got caught doing something like DWI or causing trouble,they would often take the perps to the state forest (the "res") and beat them sensless,and leave them there,let them walk home--just as often as they would haul you to the station and book ya!...
..we always wore our halos in Fall River!..
Thats more than I paid for the heads!!!
coughjustshouldaboughtAFRcough![]()
They are f'ing you big time. Resurfacing the heads shouldn't be more than $125 - $150. And new valve seals are maybe $32 tops. Valve springs should be a couple hundred dollars, maybe. You are getting ripped off.
For that price you could practically have a brand new pair of Edelbrock heads. Or some Darts would be even better. Both of them use castings and machining made in the USA, instead of the foriegn castings of the patriots.
I don't think you should buy new heads since you already have them, but I would definitely tell them to go pound sand.
Have them resurfaced (probably somewhere else depending on their price), and buy new seals and springs/retainers yourself, and for $60 you buy the tool and put it back together and lap the valves.
