ohio 1984 3/4 ton k5. Will consider trades
bad_bo_ti
OhiO
Click picture for more pictures. 6in susp. 3in body lift, cutout flares, 350, 350 np208, 14 ff rear 10 bolt front 3.73s in both, front has dana 44 knuckles crossover over hi steering with hydraulic assist, body is in decent shape has some rust newer floor panels, sits on 38.5 tsl's roller tires and i have 4 like new same tires, need money for a front end loader tractor, 4500 obo. zip is 43019 to mapquest it. thanks, chris pm for pics
ttt may consider trades. such as an s10 or a good daily driver good mpg car
be interested in trades on the silver truck on the trailer? Not a spec of rust on it. any interest ill get ya the specs! not a 4cyl in gas mileage by any means but i used it as my daily driver for quite a while, very nice running truck. about 13-14mpg in town
dont have a driveshaft that will fit it, and all the shocks are not hooked up. the fronts because i was going to install the ford shock towers which i have adn will go with the blazer and the rears are not hooked up because i was going to make a cross member for the them to mount inbetween the frame rails because the original axle mounts i cut off to run line for the disc brakes.
ttt, need money to start garage, am i priced too high or what? thanks, chris
