badmix
I keep a couple heavy duty plastic boxes in my blazer that contains all fluids (oil, trans, diff) incase of problem on the trail, i also carry hoses, belts, etc etc.
Being that its a gazillion degrees here in florida, ive had issues with factory plastic bottles splitting at the bottom seams and coating the bottom of the box with whatever fluid let go.
My plan was to get some metal 1 gal. fuel gas and putting the oils and fluids into each can. My question is, i know the plastic bottles are "sealed" , would it hurt to open the factory bottles and pour the contains into metal cans. I know when you open brake fluid that if you dont seal it up, itll absorb moisture. Id be worried about fluids degrading over time once they are opened. Not sure if this is an issue or not.
thoughts?
thoughts?
