When I ran Power Service in Big Ugly folks mentioned lube troubles with the ULSD and ND30w was recommended to rectify this. Sort of a "better than nothing" solution to the problem. I put one once in for ever gallon of gas I put in and had no issues for two years. I've since switched to 4x4xGod's ACES diesel fuel treatment stuff and stopped adding the oil. Truck seems fine and doesn't smoke slightly under heavy throttle like it did when I put the 30w in.
Thanks for the mention, Andrew!
My take on oil as a fuel additive:
yes, motor oil and ATF will " burn", but as for actually providing lubricity, nope.. all it's doing is turning to carbon in there..and the metallic additives , and polymer viscosity indexers leave deposits when the base oil goes poof...and heavy oils also affect cetane and fuel viscosity, which can lead to other issues.
even two stroke oil turns to a nice carbonaceous goo.. gotta remember, a truck isn't a lawnmower..and the two stroke engines it's designed for don't produce the combustion temps that your truck does..
IIRC, a direct injected two stroke has combustion temps of around 120F...a four stroke diesel produces combustion temps anywhere from 750 F to over 1000F, depending.. The common rail injection systems generate serious heat too, so coking at the injector tip is a real issue.
Now, I know guys burn whatever in their fuel and "have no problems".. if the engine isn't grenading, I guess that's success to some people..maybe on the older stuff it's not a big deal to dump whatever in.. If emissions, ring land deposits, injector coking, and bore scuffing aren't a big deal, then rock on..
