My dad always said oil is cheaper than engines,rings & bearings.....
3000 miles might be "early" for todays oils,but back in the day,3000 miles was the limit..
It will only hurt your wallet a little by changing the oil "too soon"..and a new filter EVERY time is well worth the 5 bucks too..preferably not a FRAM filter !..
When my dad worked at the gas & electric plant,the management decided to try something different--on one of their fleet vehicles,a 60's Dodge Dart wagon with a slant six,they did not change the oil after the first "break in period"--instead they just replaced the oil filter,and added a fresh quart..that car went well over 100,000 miles and still ran fine,no smoking,or ticking--but those old slant sixes were well known for running "forever" even with practically zero maintenence..
I've seen several later model engines that never had the oil changed very often,and still looked clean inside the valve covers--many of them were "off the stick" when my friend went to do an oil change on the customers vehicles that didn't know squat about their vehicles,running them too low on oil is what kills 90% of the engines he has to replace..people see the oil light come on,floor it,and pray they make it home..usually they dont!..
The 2.7 Mopar engines seem to be sludge factories,my friend has replaced many of those engines and almost all of them after being torn down to see what happened,had a ton of gook in the crankcase and lifter galley..those engines look like a 1000 mile oil change interval would be better,especially if its used in short runs often in cold weather..
