I like Lucas oil treatment,but I have learned adding a bottle to my 6.2 will do a few things--some good,some bad..
It will :
Quiet the noisy "box of rocks in a clothes dryer" sound the 6.2 is famous for..
Help reduce oil leakage at various places like valve covers,seals,etc..
I think it congeals like jello when it cools around areas that have seepage..
It seems to reduce friction and you can actually "feel" the engine running smoother with it vs without..
It seems to help a older ,slightly worn diesel start faster in warmer weather,by sealing the rings and boosting compression a bit..
But it also will reduce the chances of getting the old 6.2 to fire up on a cold winter morning,the drag on the starter will kill the batteries a lot faster...
Also the thick oil will not flow very fast throughout the engine if it does start--you are likely to hear lifters chatter or a bearing rattle for a few seconds until it finally gets "everywhere"..you do not want to go reving the engine too high right after a cold start with Lucas in the oil..
I have seen the Lucas transmission treatment bring a few dead transmissions back to life,at least temporarily,a few lasted several months until the owner either got another transmission or got rid of the car..
I have only used the fuel system treatment once,didn't really notice much difference..I think the 12 bucks would have been better spent on another 5 gallons of fuel..I don't think it has any anti-gel effect on diesel fuel either...I've been leery of fuel additives that say "good for gas AND diesel"...Lucas may not have any alcohol in it,but many other brands do,and that isn't good for diesel injector pumps and injectors..
