oil cooler line quick question
isaac
i am about to change out my oil cooler line it came in today from napa. my question is do i need to put any teflon or anything on the threads to keep it from leaking or can i just install them as is? thanks any input would be appreciated.
The oil lines should be a saganaw fitting. Replace the O ring or re-use the old one. That is what makes the seal the threadded fitting is what holds it in place. NO TEFLON.
Good point. Forgot about the pressure side.
thanks guys. going to tear into it in a while
