Xtremjeepn
I need to stop my truck from leaking. Looks like it is going to be a oil pan gasket, front & rear seals, valve cover gaskets and oil sender.
This is a K30 crew cab with first gen 454. I crawled under it last week and it looks like the pan has a very tight clearance to the engine cross member.
Will the pan come off without raising the motor? Any other tips?
