tauchen67
Registered Member
Newer 350 (dip stick on the drivers side), had a leak on the old cork oil pan gasket. Bought the single piece blue rubber "universal" gasket.
-First try i did not put any gasket sealer because the directions said not to and just cleaned it with a shop rag, no brake cleaner.
-Second try, gasket sealer in the corners like a few message boards recomended, still only cleaned with a shop rag.
-Third try, cleaned everything with brake cleaner, razor blade, the whole 9 yards gasket sealer all around, on the threads.
i tighted the bolts to "snug" on my torque wrench.
each time it leaks when i rev up the rpms, and it is on the passenger side when the dipstick hole would be for an early model 350. My next step it to try either the late model specific gasket or just try the good old fashioned cork. Any thoughts?
