to start off its a 87 350 176k miles. i have never had pressure issues before but during a 250 mile trip when I stopped in traffic I noticed my oil pressure at about 15. before this after it warmed up it would only go as low as 20 at idle after a long run. now after only a 10 mile drive on the freeway at idle it is getting around 10 or less and at cruising speed its 30ish. its not really consistent either at times. when its cold it will be at 60 and other times around 30. I did replace the sending unit about 6 years ago cause it was leaking. also the truck sat for a year while i was gone and my wife would start it up every month and warm it up but when i changed the oil after i got home it had some chunks in it. i ran some seafoam in the oil for about 600 miles then changed it again. it runs fine and i dont have any noises from the motor. i have read on here to use a manual gauge to check the pressure and see if they match. i was just going to replace the sending unit again just in case it got a chunk of crud in it and turn the motor over with it removed to flush out the fitting then get a manual gauge if it stayed the same. could I have spun a bearing and that would be causing this and could i check that with out pulling caps on the crank. and if i did how long can i expect the motor to last just driving 20 miles round trip to work. i moved for work so i dont have another vehicle right now and need to figure this thing out. any tips would help. also i have always used 10w30 oil in it.
