Oil Pressure Problem!
Mr.Jimmy
Albuquerque, NM
buddy o mine's got a 02 gmc z-71, his gauge will peg out so he'll shuter down. starts it back up and itll run low psi then itll vary a while. whats going with it. opinions appreciated.
I don't know much about the newer trucks, but I would suggest he replace the pressure sender and see if that clears it up. Start with the small easy things, brother!!! :thumb:
newer trucks have dash cluster gauge problems. best check with dealer to see if its under recall or tech bulleten for problems.
38377k5 said:
Take out the oil pressure sender and hook up a stand alone oil pressure gauge and see what it says.
What he says. And if it still acts screwy......nuke it from space, it's the only way to be sure.:D
