The normal use port above the oil filter doesn't have enough clearance for the Auto Meter electrical sender....headers are too tight to the block.
Can I use this port and plug up the normal one?
I don't see why not. I know mine, and most others I've seen mount the sensor to a fitting at the back of the intake manifold, but any of those oil taps should be fine. Of course, always verify that any tap you use is actually for oil. I had a guy who thought he was going to undo a screw-in plug used to drain the block of water (boat motor) and he called to ask why his sensor wouldn't fit...
Would be on the block behind the distributor and manifold on top toward the drivers side and one on the front of the block pass side if that's a Gen 1 SBC .
There are 4 (IIRC) 1/8" NPT ports along the pan rail edge which you've identified that could be used but I would use the correct port on the block behind the intake manifold near the distributor. The plugs along the side of the block are very hard to remove usually.
I don't have a port on the back of the block behind the dizzy guys![]()
Well photobucket is sucking at the moment and my pics aren't loading o find one. The plug I'm talking about is a 1/4 pipe about 2" above the pan rail (and the smaller plugs you found), most likely a female square drive plug that'll be a bitch to remove. It'll be on the drivers side, directly opposite of the fuel pump boss.
you should be able to get ANY npt adapter from ANY competent parts place..napa, etc.. it's not anything special...
god. you guy's need to stop feeding that machine.. it's like praying to the debil... go to Napa, pay the extra 41 cents and maintain some dignity...
Believe me Paul, I know. It was the closest to the house. I walked in and asked the guy if I could look thru his brass tray. No trays anymore. I tried...
fight the machine tho mang.. I literally laugh at the vatozone people...
