Oil pressure
I have to run some thick oil in order to get decent oil pressure like 20-50. I blame the low oil pressure on this oil additive I used for two oil changes, "Engine Restore" the stuff did jack **** and made my engine worse than it was, but the engine still runs like a million bucks even if it has A LOT of miles on it.
I could start picking the ac delcos up from work, do you happen to know off the top of your head which filter I would need?
Whatever it calls up for your 350. I can't recall the pn#, but it's by far the most common filter out there.
Rene
Remember as well that the Napa Gold line of filters is made by Wix. They are a very high quality filter, and long lasting as well.
I like bosch filters too..I'll never use a fram again.. I had one that had a "dimple" where the o - ring seats.. I found that out the hard way, after I changed the oil on the wife's durango, and promptly lost most of it when it got up to a high enough pressure..
the guy at the parts store saw the f'ed up filter, and said, " that shouldn't happen".. well, no crap.. anyway, he gave me a bosch, and all was well..
never had an issue with AC's either..
there is 70K something on my truck and there has allways been a fram on it. Never once had a problem with them.
