And they are about 1/2 the HP and torque and would be lucky to see anything over 4k rpms. Less forces also trying to squeeze that oil out. I've had one of those motors and never concerned myself with oil pressure. From everything I have read 10psi per 1k rpm is the absolute minimum you should run. So 40 psi at 5k rpms I could see it being a problem.Im just confused. "oh no my oil pressure drops all the way to 65 psi at times!" ? I consider anything over 30psi to be good oil pressure. You had other issues if you toasted your rods/mains with 40 psi. There are 200k mile motors around here(on the site) that have never seen 40psi in their lives.
. I didn't pay attention when I installed it so I am not sure. Other then checking clearences I didn't inspect the crank.
