if you run the thicker oil in the cold wether you will do more wear on startup, but if your rings are worn that probably means your bearings are worn too so youll be looking at a rebuild soon, so if you dont want the hassle of adding oil often run the thicker stuff, if you want to squeeze a few extra miles out of the motor run the thinner stuff.
