Oil Sending Unit... Need Quick Help!!
SAVAGE1
BAY AREA, CA
I'm bout to fire up the new crate engine and I need to plug in the mechanical sending unit. I still have the stock one in place at the back of the intake manifold. Is there another place I can stick the mechanical sending unit. There's a hole on top of where the oil filter mounts. Can I use that one? Thanks in advance.
Why can't you use the original hole at the back of the engine? Just take out the stock one.
David
I have two sending units at the back of the manifold joined with a T fitting. One has 3 wires (supposed to be a choke switch/ oil sending unit) and the other only has 1 wire. Can I put the Mec sending unit in place of the 1 wire sensor?
