B
bnc04
Guest
I had this posted in the garage thinking I may get more readers but I am reposting here to see if there is any suggestions that you can come up with.
Sorry about the long post but I wanted to give all the data I could so as not to waste your time
88 Chevy 90k on it. Original 350 TBI. A/T
Purrss along just fine and starts up fine most of the time.
Periodically, when the brakes are pressed or turn signal is used or blower motor/air or heater is on of windows are used or radio is used or headlights are used or any above the combination is used, the voltage will drop and the truck will start to idle rough. By drop, it could be anywhere from the original 13 down to 10 or 8 or to the red line. Most of the time, it will recover and purr along like nothing happened.
It also has this symptom, When attempting to start, buzzer, lights etc are all fine and it will not turn over at all. Sometimes, holding the key in the start position (5-20 seconds)will allow it to fire. Sometimes not.
It stranded the wife yesterday and I need to get this addressed now.
Yesterday I fixed it by tapping the starter and solenoid, it fired up and ran great all the way home. When home it did not start the first time I tried then fired on the 2nd try. After that it fired fine. It was dark and late so I didn’t do any trouble shooting.
I did an conversion to a quicksilver megashifter a year or so ago and I can’t remember if the scenario started around that time or not but I think it did.
I also installed backup lights at about the same time.
Other than that pretty much stock.
I have replaced the alternator about 6 months ago. I cleaned out and made sure I had good grounds at the taillights and wiring back there. Replaced the brake plunger actuation switch. The automatic shift coller is fully rotated to the left. I added grounds to the engine compartment, ( firewall to battery) The engine grounds look good and I have continuity from the engine to batt ground and frame to batt ground.
I’m going to pull the starter this morning and have it tested but it being so intermittent makes me think testing will be of no help.
Can you guys list what steps I should take to see if I can narrow this down a little?
I’m nowhere near as savy as you all so you may have to explain things a little more clearly at times.
Can I start pulling fuses when this happens to see if I can isolate a short somewhere?
Sorry for the long post, But I have a few hours t lay with it this morning and this weekend would like to get a game plan together to fix this thing.
Thanks for any help and suggestions. I’ll write them all down and start looking at each one.
Brett in Colorado
Another update if this helps.
Volts across batt sitting not started. 12.23
Volts across batt when running 14.5
Volts acorrdding to voltmeter in truck about 10 when truck is running.. Sometimes will go to 14 and sometimes to 8 depending on turning stuff on or off.. see above post.
Volts according to voltmeter in truck when ing key is turned to on but not started 8.
I replaced the alt and starter solenoid with no change in the symptoms. I'll be getting and trying the ignition switch today or tonight hopefully.
I ran another ground from the Neg batt post to the body and also ran a separate ground from the block to the body since I could not see to verify the condition of the rear ground strap condition.
All the wires I have looked at seem to be n good condition and I've cleaned up what I have looked at or had to remove during the above changes.
Does anybody have any other additional thoughts on what to look for? Right now my eggs are all in the ignition switch basket.
Oh.. And yes, when I run windows or accessories ( air compressor etc) with the jey off, it draws the gauge right down to 8 when it is acting up. Other times, it works fine.)
Damn intermittent electrical is a killer.
Thanks again,
Brett
Allright, I just replaced the ignition switch and the spymtom is the same. Right now, It will not start at all. I hooked up another battery and the symptom is the same.
Does anybody have the pin out and voltages I should be seeing in an 88 blazer at the ignition box? I have no idea where to go at this point. Any help would be really appreciated.
Brett
Brett in Colorado
Thanks again,
Brett
Brett
