ripperoo187
So since I seem to work on my truck every other day, I would start a build thread.
So turns out the previous owner of my blazer was a member here on Ck5 (Thunder) found this add in the for sale section. Here is his old add:
89 Chev Blazer Silverado.
TBI, 350, 700r4, 3.73 gears, 241 Xfer case, 4" RC suspension lift (NO BLOCKS) Good 12.50 x33" AT tires. Rock sliders/steps, Receiver hitch, trailer brakes, AC, Power windows/locks, cruise, Good Pioneer sound system, tach, Clean interior except dash has a coulpe of cracks. Everything works good.
Paint and body are in good condition for a trail truck. Paint has brush scratches and body has a few rock kisses. Minor stuff.
I am the second owner of this truck. I bought it in 1999 with 52000 miles from the original owner.
It currently has 135,000 original miles. I have kept this truck very well maintained.
It has many many new parts and extras.
Engine:
TBI 350. 580 CFM bored stock throttle body, K&N filter, TB spacer, injector spacer, power charger, adjustable fpr, MSD coil. New power steering pump, Water pump, Idler Pulleys, Starter, HD fan clutch, Oil cooler, 18000gvw transmission cooler. Edelbrock TES 3"single exhaust system with stainless steel headers, Flowmaster 70 muff. Runs strong!
Trans: Stock orginal 700r4, Fluid change every year. Shifts perfict.
Front end:
10 bolt 30 spline.
New ball joints, bearings, New spicier U joints. new axles, Powertrax no Slip locker.
Rear end is rebuilt open 27 spline.
Newer drive line lengthened to perfectly fit the lift. No vibrations
Extras include:
Complete rear 30 spline 10 bolt with Detroit locker +powertrax lock rite + open carrier. Spare throttle body, U joints, plus various odd and ends.
Brakes are fairly new, new axle seals front and rear, fresh fluids front to back.
I was the guy who bought it locally in elko NV,
I drove it for a while in Denver like it was then I started doing stuff to it when I moved down to alabama.
Did a 3/4 ton swap then 1 ton swap with disk brakes and 35 spline outers 4:88. With H1 tires and lockers in front and rear.
Repainted it because it was starting to rust. (Kept the fish on the back tailgate though). I decided against shiny because I would not want to take it offroad and scratch new paint I can always repaint it.
Put a soft topper on it.
Pulled out the carpet because I ruined that crossing bodies of water and herculined the floor.
Got a "a-bomb" from diy 4x painted it with bedliner and put a smittybuilt 12k winch. Last night worked with a welder and stuck on a weld on steering box brace and bolt on one. Today I am going to try to fix some of the "death wobble" coming from my newish front axel. Maybe wheel a bit if I can convince my buddies that sand and dirt are not going to kill their trucks.
Here are some more pics:View attachment 139669[/ATTACH]
I am going to try to improve it's off road performance while keeping it relatively street mannered. It's pretty capable now.
Engine:
Front end:
10 bolt 30 spline.
Extras include:
