badmix
Well, if the tube in tube design is less effective, maybe it wont be TOO hot? Dunno. The heat exchanger I seen was basically tube in tube. The outside tube ran its fluid all the way around the outside of the inside tube and the inside tube was straight thru design. So my one question is, which inlet do you use for fresh water and which do you use for coolant? The inner tube is straight thru design, so I figure that would be for coolant? Dunno, still brain storming this. lol
