on my knees, starter troubles
AussieK5
A land girt by sea
This will be staight forward stuff for somone, I've got a starter/ign prob (would tear the whole thing apart, but had a shoulder reconstruction on Tue). When I try to crank all I get is a sound like the solenoid is engaging/disengaging real fast, this happened last week and I replaced it with a spare new one. It happened again the next day but cranked on the 2nd or 3rd go, since then no probs, now all I get is this clicking sound. Its a 73 350, all the connections are tight and clean, (did it last week), as far as I can tell there is no relay in my system either. Any thoughts-Thanks in advance.
Whatever you decide to do, as far as buying another starter, get a new one or a lifetime warranty starter.
I had some trouble on my '85 K30, which I've had for 5 years now. In those 5 years, I have replaced 5 starters.
My problem was shimming the damn thing. And the fact I was buying the 'el cheapo' starters. Even one new one I got lasted me one day!!!
I finally got fed up and bought a lifetime starter and it's still in the truck today. No more grinding or shims. No complaints either.
So, get a brand new one or a lifetime starter and you should have no troubles for a while.
<font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
Sounds like either a bad battery or cables, probably the cables. Try running a jumper cable from the battery to the solenoid and see what happens. Also try running another from the negative post of the battery to the frame.
1 tequila 2 tequila 3 tequila Floor
<a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
If you know your battery and starter are good then I'd run down the cables and make sure they are in good shape.
I've had the same problem all week. I went thru to batterys, tested the starter and tested the alternator to make sure they were good. Since I had the alt and starter out I yanked out the cables and found that my cable to starter from the battery (and a couple of other wires) was burning on my exhast manifold and grounding out causing one hell of a headache.
<font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>
When I read your post I thought yeah yeah its all good, then I thought, no no go and check again. Guess what earth prob. A big thanks for smacking me in the face with the obvious. I found it hard to believe any compnents would be at fault, new batt 700cca, leads as thick as my thumb, starter that cranks as quiet as a mouse w/o shims, so it had to be down to who was doing the spanner work, I didn't crank down the '-' post nut, finger tight only. A little to self sure me thinks.
Don't feel bad
! I replaced my battery a couple of weeks ago, got in the truck, hit the key and nothing. After throwing a fit, and throwing the hood open - some idiot neglected to put the cables on
hey, on one of my 350 blocks, i couldn't seem to shim it so that it wouldn't bust the nose off the starter, i went through about 4 of 'em, and i think the problem was compounded by a bad flywheel after all that.....
what's the deal on the cheapies, are the bodies not correctly macined to the proper tolerances or something??
rgrgegre...... greg
I don't think thats the case. AFAIK, all the starters you are buying are using GM nose cones, which will set your starter gear/flywheel distance. Gm did make cast iron nose cones, but then your block would probably bust : )
Dorian
My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
No anti-theft measures on your truck? No pity when its stolen
