ONE BIG JIMMY "Everything In TX Is Bigger!"
Will do!
One way or another I'm going to make it work without having to space out the bumper
I know I will have to make some custom mounting brackets due to the CUCV frame mounts
I had Darren send it to me without mounting holes so I can drill them where I need them.
Looking forward to seeing how the winch carrier looks after it's together.
Just read this thread, nice build.
Not sure they'd fit, but the earlier trucks had a passenger side mount that turned the batt 90 deg from what was pictured - long ways against the core support.
On the A/C you I thought you were using the holley mount - did you change up the plan on that altogether?
Still playing with mounting options on the battery thanks for the tip I will look into it
Think I have an answer
More to come on that
I stayed with the Holley bracket it worked out great
Its on there
Yes
Working on brackets for that in the next couple of days.
It's tricky due to me running the Cucv frame extensions and the way those mount up but I will post that when I get there so all can see
So my question is what color to powder coat the winch cradle? Satin black to match the trim and bumpers or the silver vein to match the frame?
Is your winch cradle setup lower to put the fair lead below the bumper or is that the normal height? Also what size tires are you running, don't think I seen it mentioned.
